Author Topic: As I recall...  (Read 1862 times)
Offline Greg Groess
As I recall...
« on: April 05, 2009, 11:22:00 AM »
This little guy gave us all fits...
Use CM and masks to get this image back to some reasonable correction.
<Derek, I think this is your original do you mind if we use it?? >
It was originally posted as a challenge image and it re-surfaced during one of the conference calls.
Offline derekfountain
Re: As I recall...
« Reply #1 on: April 05, 2009, 12:46:12 PM »
Of course I don't mind. :)
It's possible to fix this one without masks, although I can't remember for the life of me how I did it.
Offline gremurphoto
Re: As I recall...
« Reply #2 on: April 05, 2009, 01:15:19 PM »
Background layer was set to color for final correction.Slight improvement.Picture must be from "Down Under" as the horizon curves so quickly.GregM
« Last Edit: April 05, 2009, 09:13:43 PM by gremurphoto »
Offline gremurphoto
Re: As I recall...
« Reply #3 on: April 06, 2009, 09:57:05 AM »
Second attempt.I got the yellow out of the stripes using wgCMYk,then lightened the blanket,followed by a MtannedCauc skin pin.Part two was to focus attention on the eyes so I zoomed in and using RGB made the whites(sclera,thanks ganna and greg) of the eye whiter or at least more neutral.Last step,light sharpening.GregM
« Last Edit: April 06, 2009, 10:29:26 AM by gremurphoto »
