Author Topic: Sharpening ?  (Read 6321 times)
0 Members and 3 Guests are viewing this topic.
Offline Greg Groess
Re: Sharpening ?
« Reply #15 on: April 01, 2009, 06:42:11 AM »
Hey Chris,
My Firefox says that the page requires a missing plugin.
Then it says there is no acceptable plugin to be found.
Works in IE7 but crashes on exit.
« Last Edit: April 01, 2009, 06:47:11 AM by Greg Groess »
Offline derekfountain
Re: Sharpening ?
« Reply #16 on: April 01, 2009, 07:13:05 AM »
Derek, could you spare a minute and confirm that http://www.broadhurst-family.co.uk/Blending/InteractiveBlending.htm also fails under firefox
Yes, as Greg says, it asks for a plugin. I'm not sure what it's after. Ignoring that, most of the buttons are inactive.
Offline gremurphoto
Re: Sharpening ?
« Reply #17 on: April 01, 2009, 10:08:17 AM »
Chris,I took one of your images and after a SHN in CM,tried the few sharpening techniques I know on it.The one I went with was the USM at 20 amount and radius 10(I tried 20) The improvement was to the drape of the clothing,almost 3-D.Yes,there is a halo behind the woman in the red dress and there was a color shift after sharpening but I think the picture has a certain verve.GregM
« Last Edit: April 01, 2009, 10:22:19 AM by gremurphoto »
Offline themightyzog
Re: Sharpening ?
« Reply #18 on: April 01, 2009, 11:18:17 AM »
Derek, I think I have identified the javascript problem and altered it for just this page
http://www.broadhurst-family.co.uk/lefteye/MainPages/statue_ni.htm#
Can you see if it works, in which case I'll change the others as well
Chris
Re: Sharpening ?
« Reply #19 on: April 01, 2009, 12:03:42 PM »
Yes, that now works! :)
Offline Greg Groess
Re: Sharpening ?
« Reply #20 on: April 01, 2009, 12:47:48 PM »
are you sure you don't write web pages for a living??
It works just fine...
Re: Sharpening ?
« Reply #21 on: April 02, 2009, 08:33:45 AM »
Hi, I've changed all the sharpening pages for FireFox if you want to compare them
Offline ganna
Re: Sharpening ?
« Reply #22 on: April 02, 2009, 12:29:11 PM »
Chris, thank you so much for this. I'm starting to to see more light about blending and looking so much forward to the rest, esp on how the "blend-if" story works.
Kind regards
Re: Sharpening ?
« Reply #23 on: April 02, 2009, 12:48:20 PM »
Kind of you to say so Ganna, I found it very useful too - being able to quickly switch between blends and control the Opacity.  I thought I had included all the important ones for us photo folks, but now ones like Linear & Vivid Light are beginning to be used by people, but understanding what is exactly happening is a little much for my old grey cells!
Hope you are finding the course useful - it took me 3 goes at it before I begun to feel a little comfortable (but then only rgb & lab)
All the best
Chris
