Author Topic: Work Flow issues  (Read 5766 times)
Offline Rick Moore
Re: Work Flow issues
« Reply #15 on: April 02, 2009, 11:25:14 AM »
Howdy Forum,
I finally caught up with my high school athletic team and individual packages so here I am once again with seemingly simple problems.
Is there a way to speed up the typing of the shadow and highlight numbers in the wrench box? I find my self jumping around often on a daily basis setting black and white numbers between for the web, which I leave at 0 and 255, and for print in the studio with shadows between 9 thru 21 and whites between 252 and 240. All these numbers depend on my paper and output options as to where the corrected image is to be used.
Typing 0,0,0, and then 255,255,255 then save and close and next couple of images need 12,12,12 and 242,242,242 save and close then later back to the first 0 and 255 and on becomes bothersome and most definitely slows me down.
Just my first thought of the day as I just hit two changes in a row and thought about it again.
Regards,
Rick
Rick Moore Photographer
www.rickypics.com
Offline curvemeister
« Reply #16 on: May 06, 2009, 05:36:37 AM »
Coming late to the party here, folks.  Greg has suggested a good work-around, and I agree this is a bug.  Deleting the neutral should not affect the highlight and shadow points.  It's on the bug list, and should be dealt with as soon as - and this is a big one - the 32 and 64 bit beta versions are squared away.
