Author Topic: Patch Tool seems to be affected by CM  (Read 2391 times)
« on: February 01, 2009, 10:08:26 AM »
On each PS CS3 or CS4 session, after CM was invoked for the first time the patch tool does no longer work as it should: The effect of moving the selected area to the target region is no longer visible on screen. In order to use the patch tool I have to apply it blind.
Offline Alex314
Re: Patch Tool seems to be affected by CM
« Reply #1 on: February 01, 2009, 10:30:26 AM »
I can confirm that this bug here also appears to be present (CS3 - XP pro - CM 3,0,12,0).
Regards,  Alex
Offline derekfountain
« Reply #2 on: February 01, 2009, 01:21:09 PM »
Yes, CM corrupts the behaviour of several of the movement tools:
http://www.curvemeister.com/forum/index.php?topic=2022.0
Offline curvemeister
« Reply #3 on: February 01, 2009, 07:37:22 PM »
Thanks for reporting this, Michael.  I knew that this happened, as Derek says, for dragging a selection.  With a bit of luck, this additional behavior will help me narrow down what the problem is.
