Hi Mike
Gregg suggested I send you this, I am running windowsXP 32Bit with 2megs of ram and photoshop CS4, I have CM3.0.12.0 have started the Curvemeister Jan. 101.
The problem I am having is that when I try and set my control points for shadow, highlight etc. the point does not follow the curser very well. At times I have to grab it a couple of times and if I drag slowly it will follow up to 1/4 inch behind, if I drag fast it will leave it behind. I can set the points by dragging very slowly and when I am close. Hope this makes sense.
The other problem is when I go to settings and change to 0-255 it will not change in the program, it always stays at 0 to 100%, this is for the lightness in Lab mode.
I understand that CS4 sometimes has problems with plugins that were made for CS3, for instants if I have NIK plugins installed my "arrange documents" button will not work in Photoshop. Greg has been trying to help me with this and has suggested I post it here.
Gary
