Author Topic: Bit of a problem image  (Read 2383 times)
Offline themightyzog
« on: November 05, 2008, 02:48:17 AM »
Hi,
I've been a bit busy organising a photo exhibition with the objective of getting local people more interested than just taking snapshots - got quite a good response of 27 people & 140 images.
Here is a (snap!)shot from the event (not taken by me) - I had great problems with sodium lights in the church - most I replaced with tungsten (5 out of 6), but this shot has both in there as well as a touch of daylight.
See what you can do with just CurveMeister - although a touch of focusing/sharpening wouldn't come amiss as it was 1/4sec handheld.
Offline gremurphoto
Re: Bit of a problem image
« Reply #1 on: November 05, 2008, 11:05:20 AM »
Chris,here are two CM corrections.Corrections two improves the color of the wall but not much else.GregM
Offline gremurphoto
« Reply #2 on: November 05, 2008, 11:07:20 AM »
And some sharpening.Last pass was a bit of color in Lab for the photos in the foreground.
« Last Edit: November 05, 2008, 11:09:30 AM by gremurphoto »
Offline Greg Groess
« Reply #3 on: November 05, 2008, 02:18:30 PM »
Ok...
I went for the easy kill shot....
I used the conversion files Mike has so kindly included in the program.  There is a ACV file you can load using the convenient "Load" button, that converts Tungsten to Daylight in RGB.  Shot 1 and 2
I then set a neutral. and closed the image.
I reopened in LAB and re-set the neutral.  I then tweaked the color saturation a bit and adjusted the L curve to open the shadows a bit.  Shot 4
Offline gremurphoto
« Reply #4 on: November 05, 2008, 09:00:34 PM »
Image rethought.In RGB with new shadow,etc points.
Offline Greg Groess
« Reply #5 on: November 05, 2008, 09:29:07 PM »
even better...good work....
« Reply #6 on: November 06, 2008, 03:10:12 AM »
Wow - I think that is excellent GregM
And thanks Greg for the conversion info - there's just too many things for me to remember with CM.  I must start making crib sheets!
