Author Topic: 2.4.9 not working in CS4 32-bit but ok on CS3  (Read 2867 times)
Offline rosenjer
« on: November 04, 2008, 03:06:55 PM »
I can't seem to get any response from CM in CS4.  It starts and show the curve and can run the wizard.  However, I see no changes nor does the color picker come up for the wizard.  Still working well in CS3, however.  Unistalled and re-installed via the 2.4.9 updaet.  Am I missing something?
Thanks,
Jerry
Offline curvemeister
Re: 2.4.9 not working in CS4 32-bit but ok on CS3
« Reply #1 on: November 04, 2008, 06:13:30 PM »
You may be the first person to try running Curvemeister 2 on CS4.
I haven't yet tried it with CS4, but will do so in the next few days.  I can't guarantee a fix, but if it is relatively simple, I will provide a free update for Curvemeister 2 to run on CS4.
Offline photodoc
« Reply #2 on: November 05, 2008, 10:44:25 PM »
I tried the same thing - curvemeister shows up in CS4 on the filters menu and will activate showing the lab, rgb, etc menu, but when you change curves nothing happens.
Thanks
PhotoDoc
« Reply #3 on: November 06, 2008, 12:42:07 AM »
Thanks for the heads up. CS4 obviously does not agree with the older version of Curvemeister.  I'll have an updated status here shortly after I recreate the problem and try to determine what is causing it.
Offline photodoc
« Reply #4 on: January 23, 2009, 09:31:16 PM »
Any updates? Thanks!
« Reply #5 on: January 25, 2009, 11:19:11 PM »
There is definitely a problem with Curvemeister 2 and CS4.  Curvemeister 2 is more intimately tied to Photoshop's window layout, since it replaces Photoshop's image window with its own window.  Curvemeister 3 does not have this problem, because its window llayout is independent of Photoshop's.
I don't have a workaround as yet, but there is a possibility that disabling tabs, and using the F key to rotate through the various window display options will fix the problem.
If I can do it in a reasonable amount of time, I will fix Curvemeister 2 to work with CS4, but I cannot promise this.  When I have a free moment, I will see what is involved in fixing the problem.  If I can't fix it, then it would be necessary to upgrade to Curvemeister 3 to use CS4.
Just to clarify- the current version of Curvemeister, version 3 works with CS4 - the problem being discussed is with older versions of Curvemeister, versions 2 and 1.
