Author Topic: Photoshop CS4 and 64 bit support  (Read 11429 times)
Offline curvemeister
Re: Photoshop CS4 and 64 bit support
« Reply #30 on: May 06, 2009, 11:53:48 PM »
Hi William,  I sent you an email with the download location, and you are now a member of the beta group
There is a problem that affects installing on some systems - the plugin does not show up where it should and needs to be manually copied.
