Author Topic: Photoshop CS4 and 64 bit support  (Read 11429 times)
Offline jrowell
« on: October 17, 2008, 08:17:47 PM »
Will Curvemeister run in the 64 bit of CS4?
« Last Edit: October 18, 2008, 01:15:56 AM by curvemeister »
Offline curvemeister
Re: Photoshop CS4 and 64 bit support
« Reply #1 on: October 18, 2008, 01:15:32 AM »
Not yet.  I plan to have a 64 bit Curvemeister 3 by Nov 15, however this could change.  I will announce any changes in schedule in this thread.
There will be no additional charge for existing owners of Curvemeister 3.  Curvemeister 1 and 2 will work with 32 bit CS4 only.
Offline jrowell
« Reply #2 on: October 18, 2008, 06:52:44 AM »
OK, looking forward to it.  Thanks for your help and continued support.
Offline lbenac
« Reply #3 on: October 19, 2008, 12:34:23 PM »
That would be great also looking forward to have CM working in CS4 64 bit.
Luc.
Pentax K20D
DXO 5.3/CS4
Offline mdavis
« Reply #4 on: October 23, 2008, 06:31:11 PM »
I just installed CS4 over the weekend.  What I noticed is that the program recognized that I was running Vista 64.  What I didn't notice is that it installed two versions of Photoshop (apparently) and two .exe files for CS4, one in the 64-bit ....Program Files\ folder, and one in the ....\Program Files (x86) folder (the 32-bit stuff).  I dragged an icon for each onto my desktop.  The 64-bit version Photoshop.exe file is 60,828 KB and the 32-bit version is only 49,650 KB.  Same filename, Photoshop.exe.  What I can also tell you is that the 64-bit Photoshop loads from my desktop icon in less than 2 seconds, although I have a very fast, newly built computer.  Incredible in Vista 64!
The question, then, is will Curvemeister run under the 32-bit version of CS4?  I'm not about to try it and mess something up.
Offline lbenac
« Reply #5 on: October 23, 2008, 07:37:00 PM »
Curvemeister is running under the 32 bit already - I use it with CS4 on Vista 64 bit. Of course what I am waiting for is for it and other plugins to run on the 64 bit CS4.
Pentax K20D
DXO 5.3/CS4
« Reply #6 on: October 23, 2008, 08:21:22 PM »
Yep - 32 bit should be fine.  64 bit is on the way as I can make it happen.
Offline KlausNordby
« Reply #7 on: October 26, 2008, 06:56:18 PM »
Great to hear you're on this ball, Mike! I'm on Vista x64 (which is an excellent OS, really) and plan on getting the CS4 apps sometime in November. That the x64 installer seemingly automatically installs both the 32 and 64 bit versions is neat, as we all have a lot of 32-bit-only plugins. I can only hope the other vendors will follow Mike's generous example and not bleed us badly for the x64 versions -- but I'm not banking on it.
K
Offline lbenac
« Reply #8 on: October 26, 2008, 07:24:04 PM »
The only issue is that whatever you do, the 64 bit will be open by default instead of the 32 bit. Drplets also lokk for the 64 bit and do not work very well even with the 32 bit already open. So as soon as CM and Focus Fixer are on 64 bit - live will be easier....
And yes thanks to Mike for great support in advance...
Pentax K20D
DXO 5.3/CS4
Offline lbenac
« Reply #9 on: November 18, 2008, 11:54:48 PM »
Hello,
Any update on CM 64 bit?
As soon as available I will get rid of CS4 32 bit as CM is the only plugin I "cannot live without".
Thanks.
Luc.
Pentax K20D
DXO 5.3/CS4
« Reply #10 on: November 19, 2008, 12:23:39 AM »
I have set up a 64 bit development environment, and begun to make the 64 bit version of Curvemeister.  With luck, this could be done in the next week or so.
Offline lbenac
« Reply #11 on: November 19, 2008, 01:05:33 AM »
That is really great.
Thanks.
Luc
Pentax K20D
DXO 5.3/CS4
« Reply #12 on: November 30, 2008, 07:59:52 PM »
Just a status.  I've set up the necessary hardware and software, and made substantial progress with porting some of the components of Curvemeister over to 64 bit.  The process is partly clerical - changing things to get them to compile under the new compiler, and a few head scratchers: functions that have been changed in ways that require significant changes.
I cant' give a definitive date for completion - I had estimated two weeks ago, but other items, including the recent beta releases, needed to be cleared up before I could really proceed with the new 64 bit code line.
Here's hoping for a 64 bit beta release in the next two weeks.
Offline lbenac
« Reply #13 on: November 30, 2008, 08:05:30 PM »
Thank you very much for the update.
You are still ahead of the "curve" judging by the number of my plugin that have no schedule as even when they would start the conversion  ;D
Good luck and all the best for the work ahead of you...
Luc.
Pentax K20D
DXO 5.3/CS4
« Reply #14 on: November 30, 2008, 11:09:00 PM »
Thanks.  I'll keep you posted.
I'm surprised at how long it is taking other companies to pick up the ball on 64 bit.  This is the first time that Adobe has "pulled the plug" on Windows plug-ins, so many companies have been caught off guard.
