Author Topic: not lego, not skin . . . Paint!  (Read 6428 times)
Offline Jean Pierre
« on: September 05, 2008, 01:39:42 PM »
Hi everybody.
I dont know how you manage to create pins for lego pieces.
I was thinking it would be interesting for me (me,me,me) to create pins for Winsord & Newton tubes for painting.
Lets say ' cadmium red ' a kind of chinese red.
How can I do that?
JP
Offline curvemeister
Re: not lego, not skin . . . Paint!
« Reply #1 on: September 06, 2008, 10:14:48 AM »
When noted in the pin file, the colors are scanned using a DTP24 spectrophotometer.  This is a device that measures the spectrum of colors that are reflected by an object.  Those values are used to calculate Lab values suitable for use in Photoshop.
I'm always eager to add new colors.  If you can dab the various colors of paint on a piece of paper or canvas, and mail them to me, I'll gladly scan them in with my spectrometer.
Another possibility - does Winsord & Newton the equivalent of a swatch or paint chip book?  If so, I can scan that in.
Another way would involve photographing the swatches of color next to a standard reference, then curving your image to get the standard reference as close as possible.  Your paint swatches would then be reasonably close.
A tutorial on matching a scanned or photographed painting based on these pins would be a valuable addition.
I generally like to warn people that there are limits to the final accuracy of the colors, even if you use pins to anchor the Lab values to their measured values.  These limits generally require that you pick one or two important colors, that you want to be accurate, and allow the other colors to wander a bit.
Offline Jean Pierre
« Reply #2 on: September 07, 2008, 03:22:04 PM »
Hi Mike,
I painted all of the colours on 2 inches paper circles years ago. But because of the lightfastness I chosen to send you the photograph of my Quiller wheel which you will be able to adjust.  The printed colors seems ok to me.I took it under both neon 22Watts and 40 watts ordinary bulb.
I wish it will be ok. I photographed it with a Kodak gray card for you to adjust the neutral [ I have been told you know how to do it ;-)].
I also put the following colour chart on W&N web site for you to download if you wish.
http://www.winsornewton.com/assets/ColourCharts/AOC%20Colour%20Chart%204col.pdf
I wish everything is ok.
Jean
Offline Jean Pierre
« Reply #3 on: September 07, 2008, 06:10:42 PM »
« Reply #4 on: September 07, 2008, 09:44:28 PM »
Very interesting.  Unfortunately, a photograph of the wheel by itself is not going to produce very accurate pins for the colors.
It is as if you had a map of the world, made of rubber, and stretched and distorted in an arbitrary way.  Positioning some of the cities and countries in the correct relative locations (corresponding to gray neutral areas in your image) does not guarantee that the other cities (colors in your image) will be accurately located relative to one another.
« Reply #5 on: September 07, 2008, 10:09:41 PM »
Also found an the following link, albeit for water color pigments, including Winsor & Newton, and corresponding Lab color values.
http://www.handprint.com/HP/WCL/huepurity.html
I have not sorted through this considerable work yet, but it seems to me that this chart could be made into a set of pins that might be of interest to a painter.
Offline Jean Pierre
« Reply #6 on: September 08, 2008, 06:56:03 AM »
I am blowned out of this world!  ;-)
Ha! Absolutely exhausting amount of information.
Yes I could make the pins myself.  Although I wont make them all and only some usefull one on my way to painting; it is to say paint first, make the pins if you have time left ;-)
But, later, maybe, I will offer them somewhere on this site.
Thank you very much
Jean
Offline Greg Groess
« Reply #7 on: September 08, 2008, 08:19:27 AM »
Jean,
You can create one pin using the numbers, then after you save the pin you can edit the pin file and add the pins as text to the file.
You could copy the pin string to the clipboard and keep pasting it into the file.  Then just edit the values and in a half hour or so...Pooof!  Instant Pinfile.
Let me know if you want more than this...
Offline themightyzog
« Reply #8 on: September 08, 2008, 09:01:46 AM »
Mike, that is an interesting page.
I notice that they have Lab Hue angles (arctan(b*/a*)) - are these very different from the 'normal' HSB angle?
Offline jacobolus
« Reply #9 on: September 08, 2008, 05:56:13 PM »
The "color vision" section of that handprint site is the best color theory/color science overview on the web.
« Last Edit: September 08, 2008, 06:35:10 PM by jacobolus »
Offline Jean Pierre
« Reply #10 on: September 09, 2008, 04:07:44 PM »
What is clipped with this text?
Is this OK?
And by the way, what is the utility difference between pins and swatches?
« Reply #11 on: September 09, 2008, 04:50:21 PM »
I'd need to look in more detail (working on the installer checker right now).  One thing that I notice is that there are two tabs separating some of the columns, and it should be one tab.
Swatches was the old name for pins, internal to Curvemeister.
Offline Jean Pierre
« Reply #12 on: September 10, 2008, 06:52:41 AM »
Should I put my file in the swatches folder too?
« Reply #13 on: September 10, 2008, 10:23:25 AM »
That will work.  You can also right click on the pin pallete and load the file directly.
Does tthis mean that Curvemeister is now working on your system?  If this is the case, then perhaps I can stop working on the "CmChecker" program and help with the pin file.
Offline Jean Pierre
« Reply #14 on: September 10, 2008, 11:47:39 AM »
It does work.
Although a file describing all the keys setted  in the registry and the tree of the installation would be fine for everyone and every software.
By the way, yours, is very good in my opinion.
I used the free 'Unlocker from a french Cedrick Collomb' to get rid of the folders.
http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe
