Hi Luc,Is it possible that you are using a newer version of the Camera Raw plugin?
Luc, If you can email me one of your files with the Pentax profile, I can see if I can recreate the problem. Send it to mike (a) curvemeister.com
Luc - I don't believe I received the file, and would still be interested in testing it.Micke, I do not use ACR for my conversion at all but only CaptureOne. How would a new ACR release help?BTW - Adobe has acknowledged the "black Lab" problem, and will be fixing it in the next ACR release. Hopefully this will also fix the purple sky issue that you discovered.Cheers,Luc
