Interesting and different from your initial posting (assuming I read it correctly).
Am I also correct in thinking that by effectively doing an auto-levels on the channels, there are now big gaps in the histogram? I had thought of doing this and came to the conclusion that a bit of blurring would be in order to smooth things out again. Perhaps I am missing something here.
There certainly is lots of room to experiment with your initial idea - but for simple people, like me, I need to pre-visualise what will happen when I curve - your action does not give me this.
This is extremely intuitive as any point on the image is at exactly the same point on all 3 curves - not as powerful as your action, but great for relatively simple adjustments.
and also it would be a heap better to just have one adjustment curve layer, rather than having to switch between them, which is extremely slow.
I do not like the Lab channels being shown back to front in our action! b-a-l
But I now have, I believe, refined this method slightly, by using Soft Light instead of Linear Light as the blend mode -- that gives much more subtle control.
I wonder if PS scripting would help, by allowing one to pick the seed mask (from any colour space?) rather than have the 3 lab channels.
Well I've had a 10 minute bash having to use all the Ladder layers and the result beats my previous attempts in rgb & lab
Well, when you say “more subtle control,” what you mean is that the target layer has less impact on the source layer, so you can move the curves more significantly before going far outside the realm of real colors. Making the control “more subtle” is indeed a good idea, hence the “zoom” layers in my action, posted above.
Soft Light, however, is not the right tool for this, in my opinion. Using Soft Light makes it impossible to lighten blacks or darken whites, and makes the effect of moving the curve by some amount unpredictable.
It probably will not work in PSE because of the poor support for Layers and such...Greg
