Author Topic: Is it possible to exit CM and have a mask loaded?  (Read 3492 times)
Offline Bulldoggie
« on: August 25, 2008, 10:52:02 PM »
I was working on an image tonight where the Hue mask was almost perfect for what I needed. But I couldn't figure out how to exit CM with the mask showing up as a mask in the PS layer to do the extra work on it (mostly making sure the B/W conversion was correct all over). That mask, after the cleanup work using PS tools, would have been useful for other layers.
Is there anyway to get CM to load the mask as an alpha channel (or something equivalent)?
Offline curvemeister
Re: Is it possible to exit CM and have a mask loaded?
« Reply #1 on: August 26, 2008, 12:04:39 AM »
Right now you can copy the mask to the clipboard, then alt click on the layer mask in Photoshop and paste into it.
Offline Bulldoggie
« Reply #2 on: August 26, 2008, 05:15:49 PM »
Cool! That will do the trick.
Offline Glossy
« Reply #3 on: August 08, 2009, 04:24:34 AM »
Thanks for the tipp. It works.
But not always (for me):
If i the mask invert (over function invert) works it not. Then not the inverse mask is copied, but the normal mask.
It functions with me only if I invert the mask with the mask curve.
Greetings Wolfgang
Excuse my bad english.
« Reply #4 on: September 26, 2009, 02:53:51 AM »
Thanks for the info.  I'll add this to the bug list.
