Author Topic: Move Tool in CS3 (don't see objects when moving after using Curvemeister)  (Read 2254 times)
Offline maar
Hello,
I have very strange problem in CS3 using Curvemeister. Whenever I do something in Curvemeister (and it doesn't matter if I save it or discard) and then I exit then simply my MOVE TOOL in CS3 doesn't work... better say it works but when moving any object in any layer I can't see it moving until I release the mouse button. The object changes position but I can't see it moving which is relally frustrating. It really does Curvemeister because if I reset CS3 using the ctrl+alt+shift then it works perfectly until I do something in Curvemeister again:-(
Any suggestion?
Thank You!
Ondrej
Offline curvemeister
Thanks for reporting this.  I'd noticed this happening on my system, but chalked it up to a Photoshop related problem.  In fact, resetting Photoshop's preferences seems also to fix the problem, but perhaps it's just a matter of restarting Photoshop.
It's on the bug list, probably not for the next beta release but I'll keep you posted - thanks again.
Offline maar
Sorry I haven't noticed it on the bug list! Thanx for the reply! It is a pitty because every time reset PS after I do semething with Curvemeister is a little bit annoying...
