Hi there,
I have been using CM with PhotoShop CS for some time, without any problems. Due to buying a new Nikon D300, have had to up-grade to PhotoShop CS3. Now, whenever i create a dupe layer and apply CM adjustments, I get a message that there is not enough memory to complete the task. Only solution is to click OK and I'm back to the PS screen with two layers.
I am using XP Pro on a Dell 9200 with 2 gb of RAM, dual processor, plenty of hd space, 5 gb as a PS scratch disk on the second hd and the second scratch disk (partition) has about 90 gb of space. Having said that, the second scratch disk is the same as the partition that the images are stored on. I'm scanning medium format transparencies and working on a file of about 135mb.
As I said, there was no problem with PS CS, but CS3 is a different issue. Is it a PS or CM problem?
Please help as it is very frustrating!
Rex
