Author Topic: Skin Tones II  (Read 6744 times)
Offline Greg Groess
Skin Tones II
« on: February 07, 2008, 02:10:54 PM »
Well,
In my continued quest to make skin tone pinning more accessable I have created a new skin tones pin file.
I have called it SHN Skin Tones.
S for Shadow
H for Highlight
N for normal
It is based on the image file attached.
Offline Frits
Re: Skin Tones II
« Reply #1 on: February 08, 2008, 02:25:03 PM »
Thanks!
Offline billbrandi
Re: Skin Tones II
« Reply #2 on: August 12, 2008, 05:51:30 PM »
Where would I save the skin tones pin file to have it accessible from my pins menu?  I saved it in the PinLibrary subdirectory but don't see those pins when I open CM.
Thanks
Bill Falzone
Offline Greg Groess
Re: Skin Tones II
« Reply #3 on: August 12, 2008, 09:15:40 PM »
You can copy the file to the directory shown in shot1
You can also right click in the pin gallery and choose manage pins as shown in shot 2
Offline Monkeyrun1
Re: Skin Tones II
« Reply #4 on: October 01, 2008, 10:13:00 PM »
I followed the instructions but it does not seem to work in CM Elements only version. Or is there a way around this problem?
Offline joann
Re: Skin Tones II
« Reply #5 on: October 18, 2009, 02:07:03 PM »
I don't see Shot 1.... I'm lost on where to put the pins.
JoAnn H
Offline Greg Groess
Re: Skin Tones II
« Reply #6 on: October 18, 2009, 05:05:21 PM »
There are 2 images on the posting...the top half is the vista file browser and the bottom is the CM edit pins interface...
