Author Topic: Printing CM3 Manual  (Read 6646 times)
Offline gus
Printing CM3 Manual
« on: December 31, 2007, 07:30:18 PM »
Is there an easy way to print the whole CM3 manual without having to print each individual page.  I'd like to have a hardcopy for reference as I work.
Thanks!
Gus
Offline curvemeister
Re: Printing CM3 Manual
« Reply #1 on: January 08, 2008, 01:19:31 PM »
Hi Gus,
Yes, there is a printable pdf version of the manual that I make available on individual request.  I've emailed you a link to it.  Perhaps in the future I'll arrange a "print on demand" version of the manual.  If anyone can recommend a company to do this, please let me know.
Offline Greg Groess
« Reply #2 on: January 08, 2008, 02:00:35 PM »
Mike if it's a PDF could Kinko's handle it??
sounds simple but you know..they can do worse.
« Reply #3 on: January 08, 2008, 02:51:25 PM »
That might do the trick.  What I'd like to do is have a pdf on file with a place like Kinko's, and then allow people to purchase the manual from them.
Offline gus
« Reply #4 on: January 08, 2008, 06:37:24 PM »
Thanks for your help!!
Gus
Offline Pete
« Reply #5 on: February 26, 2008, 03:11:27 PM »
     Mike....I would like to have the link for pdf CM3 manual.....Thanks..Pete
« Reply #6 on: February 26, 2008, 04:21:42 PM »
Hi Pete,
No Problem.  Here's the link:
http://curvemeister.com/support/Curvemeister3/cmHelp.pdf
Offline Pete
« Reply #7 on: March 03, 2008, 08:11:51 PM »
   Mike...thank you for the link for cm3 manual...Pete
Offline lfranga
« Reply #8 on: July 16, 2011, 04:26:03 PM »
Hello,
Can you tell me the easiest way to print the entire manual to have it on hand for reference?
Lowell
Offline RonBoyd
« Reply #9 on: July 30, 2011, 05:29:58 AM »
When I try the Link I get thisa message:
ERROR 404 - PAGE NOT FOUND
Oops! Looks like the page you're looking for was moved or never existed.
Make sure you typed the correct URL or followed a valid link.
I would also like access to the PDF version.
Thank you,
Ron
« Reply #10 on: July 30, 2011, 12:53:02 PM »
Thanks for pointing out the problem.
I have fixed the link, so the help file is once again available here:
Offline RonBoyd
« Reply #11 on: July 30, 2011, 02:08:36 PM »
Much better <grin>
