I agree with Mike here (I think we really said the same thing), however, I don't often use a pin for highlight or shadow, preferring to find a neutral if at all possible and let the highlight and shadows fall where they may. I like to use the full screen curve window to judge where my high/low cutoff points are. I find that if you can pin a neutral somewhere, the highlights and shadows take care of themselves, usually. There are some circumstances where a highlight or shadow may be "off" when neutral is "on", but not often.
The big question, as I mentioned elsewhere, is the Dan Margulis question of "are you willing to bet the image (overall color balance and accuracy) on a foliage or sky pin? It depends on how accurate you must be in your "interpretation" of your shot. Since we now have a tendency to slam the saturation sliders to the wall to give our images "punch", we are not often exhibiting accurate color, rather an interpretation of our images as we want the viewer to see them. In that case, color pinning can be quick and easy.
Skin tones are best if you "nail" a picture of a known person (family member for example) and then save that tone for future use. The problem in using a skintone pin, however, is that you have to keep your subject out of the sun or tanning salons so the color doesn't change. (Maybe have one for each season of the year? ) A cheekbone may not have the same tone as an arm or neck or forehead, so be careful. Skin pins would be most useful for balancing a single shooting session so all images are consistent for that session.
QuoteI'd like to point out that you are not color correcting with highlight and shadow. Rather to me they are "special" pins that set the level. Setting a highlight should not shift the color of your image. It should set the upper limit of the pixel value for that image..same with shadow.Well, yes and no. If you pin a highlight, it will force that to neutral 255,255,255 or a shadow to 0,0,0. If you pick a highlight or shadow that isn't really a true highlight or shadow and has some color information in it, the pin will shift color of that area to a neutral (equal RGB values) which can affect your image.Curvemeister has a much better way to set highlight and shadow by pulling in the ends of the histogram if you watch all the color channels so you don't clip one before the others. This is one reason that Dan Margulis argues to use individual channels when setting highlight/shadow points.
